Initial setup
Revision as of 08:55, 8 January 2017 by G8GTZ (talk | contribs)
  • You do not need to do anything other than follow this guide
Initial set up
Once you have a Rpi and an SD card with the Portsdown firmware installed - either from the BATC shop or by following the instructions in this section of the user guide - the system must be initially setup using an external PC running 2 pieces of software - the first application is to find the IP address of your RPi when it first boots up, such as Advanced IP Scanner and an SSH Terminal application such as Putty.
  • Using a network lead (not wifi at this stage), connect the RPi to the same network as your PC, install the SD card and turn the Rpi on (you do not need a keyboard, mouse or monitor connected to the Rpi). After it has booted up, use the IP Scanner to find the IP address of your RPi.
  • Open Putty and enter the IP address of your RPi and open a connection. At the logon prompt enter the default username of pi and the password given to you with the card. The console menu will start automatically and you will see the following screen:
  • System Setup. It is important that you set your display type first here, so select Display. If you want to use the Waveshare touchscreen to control the Portsdown, select it with the spacebar and press enter. Then go into the Shutdown menu and reboot to apply this change.
  • System Setup Autostart. After you have selected the display type, you can select how you want your RPi to start up.
Your Portsdown transmitter is now set up and ready for use but will require a reboot for the configuration to take effect so go into the Shutdown menu and select Reboot. The Portsdown will now restart in whichever mode you set in the System Setup Autostart menu. Please refer to the appropriate section of the Portsdown Transmitter user guide for console or touch screen operation. If you do end up at the Linux Command Line, you can get back to the Main Menu by typing: /home/pi/rpidatv/scripts/menu.sh menu
