PicoTuner
A USB tuner for DATV using the RpiPico as the USB interface
Pico tuner hardware
Mike G0MJW is designing a PCB which will host the Serit NIM and Pico board.
PicoTuner firmware
Colin, G4EML, has written firmware which needs loading in to the Pico by the user.
Programming the Pico
This can be done either before or after the Pico has been fitted to the Minitiouner, it makes no difference. Updating to a new firmware version is done the same way.
When supported by the host software this then allows the reception of two signals at the same time. Dual channel support is currently in development for the OpenTuner software.
PCB :- These will be available from the BATC shop, or you can get your own made using one of the Chinese PCB manufacturers. The Gerber files are available here https://github.com/g4eml/PicoTuner/tree/main/Adaptor
Raspberry Pi Pico :- Surface mount version without pin headers.
The Pi Hut Part Number:- SC0915 Mouser Part Number :- 358-SC0915
Harwin Part Number:- M20-8761346 Mouser Part Number:- 855-M20-8761346 Farnell Part Number :- 3756209
Harwin Part Number:- M20-9990545 Mouser Part Number:- 855-M20-9990545 Farnell Part Number :- 1022252
Assembly Instructions
Connect J1 Pin 1 to D7
Connect J1 pin 2 to CLK
Connect J1 pin 3 to VA
