HAMTV from the ISS
The original HamTV unit was installed on the ISS in 2013 and commissioned in April 2014 and was used for a number of ARISS schools contacts in 2016 - 2018. The unit failed in 2019 and was shipped back to Kaiser Italia for repair.
Following repairs carried out last year it now looks likely that the original HAMTV unit will be returned to the ISS with potential commissioning by a visiting astronaut during Spring 2024.
What is HamTV
HAMTV specifications
- 2369 MHz
- 2422 MHz
- 2437 MHz
DVB-S modulation
- Symbol rates: 1.3 Ms/s and 2.0 Ms/s
- FEC : ½
RF output
HAMTV antenna
This patch antenna is located on the earth side of the ISS but is surrounded by solar panels, thermal radiator panels, two or more visiting vehicles and robotic arms.
Video format
- NTSC
- SIF resolution: 352×240 or D1:720×480
What is HAMTV used for?
The primary use is during ARISS schools contacts, when the astronaut will use a camera to show himself and the inside of the ISS during the VHF radio contact.
How to receive HAMTV?
Ground station antenna
The HamTV transmission runs relatively low power on 2395MHz to a simple patch antenna on the ISS. This patch antenna is located on the earth side of the ISS but is surrounded by solar panels, thermal radiator panels, two or more visiting vehicles and robotic arms. The ISS also “flies” slightly nose down to protect the cupola windows from space debris and so the RF performance, particularly when it is rising from the west, is slightly unpredictable.
Pre-amp and filter
A low noise pre-amp with band pass filter tuned to 2395MHz should be connected directly to the antenna feed point to minimise co-ax losses.
Note that 2395MHz is only 5MHz below the 2.4GHz WiFi Channel 1, so good filtering will be needed to prevent WiFi from getting into the wide band satellite tuner.
Do I need a downconverter
Unless you are using the BATC MiniTiouner Mark 2 or PicoTuner USB receiver equipped with the Serit 4434 NIM, which can tune up to 2450MHz, you will need a frequency down converter such as the unit made by DB6NT.
