HAMTV from the ISS
The original HamTV unit was installed on the ISS in 2013 and commissioned in April 2014 and was used for a number of ARISS schools contacts in 2016 - 2018. The unit failed in 2019 and was shipped back to Kaiser Italia for repair.
Following repairs carried out last year it now looks likely that the original HAMTV unit will be returned to the ISS with potential commissioning by a visiting astronaut during Spring 2024.
What is HamTV
HAMTV specifications
- 2369 MHz
- 2422 MHz
- 2437 MHz
DVB-S modulation
- Symbol rates: 1.3 Ms/s and 2.0 Ms/s
- FEC : ½
RF output
HAMTV antenna
This patch antenna is located on the earth side of the ISS but is surrounded by solar panels, thermal radiator panels, two or more visiting vehicles and robotic arms.
Video format
- NTSC
- SIF resolution: 352×240 or D1:720×480
What is HAMTV used for?
The primary use is during ARISS schools contacts, when the astronaut will use a camera to show himself and the inside of the ISS during the VHF radio contact.
How to receive HAMTV?
Ground station antenna
The HamTV transmission runs relatively low power on 2395MHz to a simple patch antenna on the ISS. This patch antenna is located on the earth side of the ISS but is surrounded by solar panels, thermal radiator panels, two or more visiting vehicles and robotic arms. The ISS also “flies” slightly nose down to protect the cupola windows from space debris and so the RF performance, particularly when it is rising from the west, is slightly unpredictable.
Pre-amp and filter
A low noise pre-amp with band pass filter tuned to 2395MHz should be connected directly to the antenna feed point to minimise co-ax losses.
Note that 2395MHz is only 5MHz below the 2.4GHz WiFi Channel 1, so good filtering will be needed to prevent WiFi from getting into the wide band satellite tuner.
If you are powering the LNA at masthead up the co-ax, you will need to place the DC inseerter AFTER the filter.
Do I need a downconverter
Digital receivers for HAMTV
A receiver, such as a typical consumer STB, that need to scan the frequency is unlikely to lock to the signal in the time available during the pass.
Receivers designed for DATV
Ideally a receiver designed for receiving DATV signals should be used. The BATC Minitiouner and PicoTuner are PCBs which host the Serit 4334 satellite tuner, or NIM, and a USB interface. This unit is designed to be built at home, requiring only intermediate skills and does not use surface mount components.
When the original HAMTV was on the air, due to a problem with the DVB tables in the transmission, the MiniTiouner software by F6DZP running on Windows had to be used.
During the last 8 years many developments have taken
