HAMTV from the ISS
HAMTV specifications
- 2369 MHz
- 2422 MHz
- 2437 MHz
DVB-S modulation
- Symbol rates: 1.3 Ms/s or 2.0 Ms/s (2 Ms/s is normally used)
- FEC : ½
RF output
HAMTV antenna
Video format
- MPEG-2, approx. 2 Msymbols
- NTSC
What is HAMTV used for?
It is hoped in the future that test patterns, including JPEG images, will be transmitted when the cameras are not in use. Note this will NOT happen when HAMTV is recommissioned in Spring / summer 2024.
Once commissioned it is unlikely that the HamTV transmitter will be on air 24/7.
Once re-commissioned, it will be tested before school contacts are undertaken.
How to receive HAMTV?
A 1 meter or larger dish is optimum but smaller antennas such as flat plate or patch antennas will work and have the advantage of a wider beamwidth making it easier to track the ISS. They are unlikely to work at low elevations.
Pre-amp and filter
A low noise pre-amp (LNA) with bandpass filter tuned to 2395MHz should be connected directly to the antenna feed point to minimise co-ax losses. The LNA should have noise figure (NF) less than 1db and a gain of approximately 15 dB.
Receive co-ax cable
Receive Line amplifier
Do I need a downconverter?
Digital receivers for HAMTV
Receivers designed for DATV
However, during the last few years many developments have taken and so we now have a choice of software to use with the USB tuner hardware:
- Ryde - Raspberry Pi 4 based set-top box software designed specifically for receiving narrow band DATV signals.
- Opentuner - PC based software developed by Tom ZR6TG
- Portsdown - The BATC designed DATV transceiver system based on a Rpi 4 has a receiver which has been tested and decodes the HAMTV signal
PC software receivers
Receiving the Signal
Tracking the ISS
Testing your system
Measuring sun noise
Portsdown DATV test system
SDR continuum mode
Decoding a local signal
Once you have checked your system sun noise and tracking accuracy it is worth testing you’re your system can receive a locally generated 2Ms DVB-S signal on 2395 MHz. You can use the Portsdown Pi4 based system with a Lime SDR to generate this signal.
Receiving HamTV
https://forum.batc.org.uk/viewtopic.php?f=2&t=8398
