PicoTuner
Once proven it is envisaged that PicoTuner will replace the MiniTiouner Mk2 PCB.
OpenTuner
Portsdown
Version xxxx onwards of the Portsdown receiver is compatible with PicoTuner but can only display one channel.
Ryde
Version xxxx onwards of the Portsdown Ryde is compatible with PicoTuner but can only display one channel.
Minitiouner software
Pico tuner hardware
Mike G0MJW is designing a PCB which will host the Serit NIM and Pico board - it will look something like this:
Full details are available here: Surface mount Pico adaptor for the MiniTiouner V2 PCB
Programming the Pico
