PicoTuner Hardware
Revision as of 19:39, 2 April 2024 by G8GTZ (talk | contribs) (→‎Testing)
Mike G0MJW has designed a PCB which will host the Serit NIM and Pico board.
PCBs, BOM and schematic
The schematic is available here File:PicoTunerFinal.pdf
Rev 1
BOM is available here:
Rev 2
The only changes on the Rev 2 PCB are R4 R5 changed for 4.1V and power LEDs are on the front panel.
Rev 2 BOM is available here: File:PicoTunerFinalBOM.xlsx
Build instructions
Note, do not install the NIM or Pico until the PSU has been tested.
The LNB supply chip, if used, is the most challenging as it is an SMD device and has a pad on the base that needs to be soldered to the groundplane. So, start with this. First solder the chip pins to the PCB, taking care to get it in the correct place. When happy, with a large soldering iron, heat the pad and poke some solder through the hole on the reverse side of the PCB intended for this purpose. Do not use too much solder. It's not hard if you take care, but note a cheap, small 25W iron wont work. Use the correct tools.
I would then progress with U4, U5 and U6, ensuring to get them in the right places, then the resistors, then D8, U1, D1, D2, the pin-headers JP1, 2 3 & 4, the DC socket and USB socket, the pin-sockets for the pico (not optional, trust me, you will need to remove it at some point), the ceramic capacitors the remaining diodes, C1, C5, the LEDs, the fuse holder, molex connectors and finally the electrolytic.
Approximate built time is 2 hours.
Testing
The first thing to do is test the regulators, starting with U1. Select external and power from 12V. Remember to fit the fuse and JP1. There should be 4.0-4.2V at TP3. There will be no supply to the rest of the regulators until JP4 is selected.
That's it. However, if you plan to use the USB port, you will need to make up a patch lead. The best way is to cut up a good quality micro-USB cable. The pinout is marked on the silk screen. The "standard" is Red V+, Green D+, White D- and Black GND.
Programming the Pico
