PicoTuner Hardware
Revision as of 18:44, 3 April 2024 by G8GTZ (talk | contribs) (→‎Rev 3)
Mike G0MJW has designed a PCB which will host the Serit NIM and Pico board.
PCBs, BOM and schematic
Rev 1
It should look a bit like this (Excepting R4 value)
Rev 3
The changes on the Rev 3 PCB are the addition of a power LED and all LEDs are now on the front panel.
The PCB should look a little like this
Build instructions
Important notes
  • It is recommend that the Rpi Pico is placed in a socket and not soldered directly.
  • Note the Pico orientation - the USB socket must point away from the edge of the PCB.
  • Note, do not install the NIM or Pico until the PCB has been tested.
The LNB supply chip, if used, is the most challenging as it is an SMD device and has a pad on the base that needs to be soldered to the groundplane. So, start with this. First solder the chip pins to the PCB, taking care to get it in the correct place. When happy, with a large soldering iron, heat the pad and poke some solder through the hole on the reverse side of the PCB intended for this purpose. Do not use too much solder. It's not hard if you take care, but note a cheap, small 25W iron wont work. Use the correct tools.
I would then progress with U4, U5 and U6, ensuring to get them in the right places, then the resistors, then D8, U1, D1, D2, the pin-headers JP1, 2 3 & 4, the DC socket and USB socket, the pin-sockets for the pico (not optional, trust me, you will need to remove it at some point), the ceramic capacitors the remaining diodes, C1, C5, the LEDs, the fuse holder, molex connectors and finally the electrolytic.
However, if you plan to use the type A USB port on the back panel, you will need to make up a patch lead to go from the Pico USB port to the white 4 pin Molex connector next to the USB socket. The best way is to cut up a good quality micro-USB cable. The pinout is marked on the silk screen. The "standard" is Red V+, Green D+, White D- and Black GND.
Approximate build time is 2 hours.
Testing
The first thing to do is test the regulators, starting with U1. Select external and power from 12V. Remember to fit the fuse and JP1. There should be 4.0-4.2V at TP3. There will be no supply to the rest of the regulators until JP4 is selected.
Programming the Pico
