Changing system setup
Revision as of 18:05, 8 January 2017 by G8GTZ (talk | contribs)
If your Portsdown transmitter is normally configured to boot up and be used in Touchscreen mode and you want to change some parameters such as station name, simply follow this procedure.
  • Connect the RPi to the same network as your PC, and turn the Portsdown on. After it has booted up, use the IP Scanner to find the IP address of your RPi.
Note, if the console menu does not appear and you end up at the Linux Command Line, you can get back to the Main Console Menu by typing: /home/pi/rpidatv/scripts/menu.sh menu
You can now make any changes you require (see initial setup for details on options) and as long as you do not change the autostart configuration, the Portsdown will automatically boot back in to Touchscreen mode when restarted.
