PicoTuner Hardware
Mike G0MJW has designed a PCB that will host the Serit NIM and Pico board.
PCBs, BOM and schematic
PCBs will be made available in the shop from the beginning of April 2024.
https://batc.org.uk/shop/picotuner-blank-pcb/
Note:- The following pictures show the optional Wiznet version of the Pico with Integrated Ethernet Port. The basic Pico model is all you need for USB operation. The basic Pico (without wireless) comes in two versions, one with header pins (the Pico H) at about £5, and one without header pins (the Pico) at about £4.
Rev 1
- The parts list (BOM) is available here: File:PicoTunerADJBOM_updated.xlsx
- The schematic is available here File:PicoTuner-rev1.pdf
- A drawing for the back panel is here File:BackPanel.pdf
- If you want to 3D print a template, this may help File:3DPicoBackPanelPad.zip
It should look a bit like this (Excepting R4 value)
Rev 3
The changes on the Rev 3 PCB are the addition of a power LED and all LEDs are now on the front panel.
- The Rev 3 parts list (BOM) is available here: File:PicoTunerFinalBOM.xlsx
- The Rev 3 schematic is available here File:PicoTunerFinal.pdf
- The back panel design is here File:BackPanel3.pdf
The PCB should look a little like this:
and when built:
Parts Availability
The continued availability of specified components is an ongoing problem for designs such as this.
The 3v3 regulator TPS78533 can be substituted with the onsemi NCV5661DT33RKG, available from DigiKey with part number NCV5661DT33RKGOSCT-ND.
Build instructions
Important notes
- It is recommend that the Rpi Pico is placed in a socket and not soldered directly.
- Note the Pico orientation - the USB socket must point away from the edge of the PCB. The pictures above show the optional Wiznet version of the Pico with Integrated Ethernet Port. A standard Raspberry Pi Pico (non-wifi) is all that is required for a USB connected PicoTuner.
- Note, do not install the NIM or Pico until the PCB has been tested.
The LNB supply chip, if used, is the most challenging as it is an SMD device and has a pad on the base that needs to be soldered to the ground plane on the back side of the PCB for heat dissipation. So, start with this chip. First solder the chip pins to the PCB, taking care to get it in the correct place and flat against the board. When happy, turn over the board and with a large soldering iron, heat the pad and poke some solder through the small slot intended for this purpose. Do not use too much solder. It's not hard if you take care, but you need a decent thermal mass due to the copper ground plane. Use the correct tools, don't be tempted to try a small 25w iron that will take a long time slowly getting the joint up to solder melting point, as that will damage the chip.
I would then progress with regulators U4, U5 and U6, ensuring to get them in the right places, then the resistors, then D8, U1, D1, D2, the pin-headers JP1, 2 3 & 4, the DC socket and USB socket, the pin-sockets for the pico (not optional, trust me, you will need to remove it at some point), the ceramic capacitors the remaining diodes, C1, C5, the LEDs, the fuse holder, molex connectors and finally the electrolytics.
If you plan to use the type B USB port on the back panel, you will need to make up a patch lead to go from the Pico USB port to the white 4 pin Molex connector next to the USB socket. The best way is to cut up a good quality micro-USB cable. The pinout is marked on the silk screen. The "standard" is Red V+, Green D+, White D- and Black GND. You can also directly solder the USB lead to the Test Points under the USB socket on the Pico; the +V line can be routed through the adjacent hole abnd soldered to the top of Pin 40 as shown here.
NOTE the correct way round to fit the Pico in the picture below
Signal | Colour | Pico TestPoint |
Gnd | Black | TP1 |
Data+ | Green | TP3 |
Data- | White | TP2 |
V+ | Red | Pin 40 |
Approximate build time is 2 hours.
Testing
The first thing to do is test the regulators, starting with U1. Select external and power from 12V. Remember to fit the fuse and JP1. There should be 4.0-4.2V at TP3. There will be no supply to the rest of the regulators until JP4 is selected.
Programming the Pico
