Revision as of 16:49, 11 January 2017 by G8GTZ (talk | contribs) (→Introduction)
This page is designed to give an brief overview of the Portsdown transmitter project - for more details see the user guide.
There's also a "where do I begin" guide
And of course an FAQ
And for interactive discussion with other constructors see the BATC members forum:
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used modes so enabling it to be used on ATV repeaters but also for RB-TV Dx working. The project involves some basic construction and is based around a Raspberry Pi with a touchscreen, an external local oscillator and a filter modulator card available from the BATC shop.
• Symbol rates to include the Reduced Bandwidth (RB-TV) modes and “normal” DATV modes
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
