Revision as of 16:30, 12 January 2017 by G8GTZ (talk | contribs)
This page is designed to give an brief overview of the Portsdown transmitter project - for more details see the user guide.
There's also a "where do I begin" guide
And of course an FAQ
And for interactive discussion with other constructors see the BATC members forum:
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used modes so enabling it to be used on ATV repeaters but also for RB-TV Dx working.
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
  • You don't connect the Rpi keyboard, mouse or monitor
  • You don't load any device drivers
  • You do not tinker with Linux commands
