PicoTuner
Revision as of 17:22, 21 July 2024 by G4EWJ (talk | contribs)
The PicoTuner replaces the MiniTiouner Mk2 PCB for all new builds, however limited stock of the MiniTiouner PCB and FTDI module will be held in the BATC shop for those who wish to continue to use the MiniTiouner software which is NOT compatible with PicoTuner.
OpenTuner
Portsdown
Version 202403110 onwards of the Portsdown 4 receiver is compatible with PicoTuner but can only display one channel.
See the following pages on using the Portsdown receiver.
https://wiki.batc.org.uk/Portsdown_4#Portsdown_4_receive_capabilities:
https://wiki.batc.org.uk/DVB-S/S2_Reception
Ryde
Version 202403220 onwards of the Ryde Receiver is compatible with PicoTuner but can only display one channel.
PicoTuner hardware
Mike G0MJW has designed a PCB which will host the Serit NIM and Pico board. The Pico can either be a standard board or the WizNet-5100-EVB-Pico which is basically a Pico with an integrated ethernet interface.
Full details are available here: Surface mount PicoTuner adaptor for the MiniTiouner V2 PCB
Programming the Pico
Ethernet Interface for PicoTuner
It is possible to fit the PicoTuner with a wired Ethernet interface, rather than USB. This interface enables the PicoTuner to be used as a 2 receiver WinterHill, or it can be used with OpenTuner software, version 0.B or later. Full details can be found here PicoTuner Ethernet Interface.
Fault-finding
When used with the Portsdown, if the message "Resetting USB Bus" appears, it generally means that power has not been applied to the Tuner. To recover from this situation, you MUST disconnect the USB connection, pause 5 seconds, reconnect the USB connection and then apply power to the tuner. Simply applying power does not solve the problem.
Subsequent "Waiting for Tuner to Respond" messages can normally be cured by disconnecting the USB connection and reconnecting after 5 seconds.
You can check if the USB connection is working by going to Menu 2, File Menu, List USB Devices. The BATC PicoTuner should appear in the list.
