Revision as of 10:25, 18 January 2017 by G8GTZ (talk | contribs)
This page is designed to give an brief overview of the Portsdown transmitter project - for more details see the user guide.
There's also a "where do I begin" guide
And of course an FAQ
Once the design is finished, built and tested Portsdown filter modulator boards will be available from the BATC shop. If you want to build your own, here is the information.
And for interactive discussion with other constructors see the BATC members forum:
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used modes so enabling it to be used on ATV repeaters but also for RB-TV Dx working.
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
  • You don't connect the Rpi keyboard, mouse or monitor
  • You don't load any device drivers
  • You do not tinker with Linux commands
