Filter Modulator build
Revision as of 17:52, 18 January 2017 by G8GTZ (talk | contribs)
There are a number of ways to get a Portsdown filter modulator board which is the only custom hardware required for the project.
  • Once the design is finalised, built and tested Portsdown modulator boards will be available from the BATC shop This is the easiest way but there will be a delay whilst they are manufactured and tested.
  • We will publishing a bare bones parts list, or Bill of Materials, as an .xls file which you can upload to Digikey - you then simply checkout and pay Digikey and it will automatically order all the parts you require to construct the board which will arrive bagged up marked with circuit references. This is the recommended way to order your parts if you decide to build the board yourself.
  • A full parts list will be published on this page and you can then order the parts from your own supplier.
We will be putting more information as we finalise the design but to get you started here are the board layout and assembly drawings:
