Revision as of 17:03, 2 February 2017 by G8GTZ (talk | contribs) (→Next steps?)
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used modes so enabling it to be used on ATV repeaters but also for RB-TV Dx working.
• Frequency coverage of 146 MHz, 437 MHz and 23cms
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
Or if you want to print off an overview of the project, we've produce a 2 page introductory brochure.
