Revision as of 15:00, 3 February 2017 by G8GTZ (talk | contribs)
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used modes so enabling it to be used on ATV repeaters but also for RB-TV Dx working.
• Frequency coverage of 146 MHz, 437 MHz and 23cms
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
