PTT and band switching
In order to make the Portsdown transmitter integrated with transmit and receive systems, Pin 40 of the GPIO goes high when transmit is selected and the signals on pins 28 and 35 can be used for band switching:
Care should be taken to properly buffer these 3.3v signals from relay transients.
The band outputs can be decoded and then used to "steer" the PTT line to the correct Power Amplifier. The Portsdown team have designed a simple board which can be either constructed on 0.1” perforated board (veroboard) or PCB details are included.
We also recommend the use of a Tx / Rx sequencer to ensure your mast head relay has changed over and your expensive pre-amp is de-powered before you start transmitting. Many circuits and pre-built designs are available including this simple single chip design by Ian Waters G3KKD published in CQ-TV 125.
Also rather than use these pins to switch an expensive RF relay on the output of Portsdown, take a look at this simple idea to use a duplexer / triplexer.
