Portsdown - where do I begin?
Shopping list
Raspberry Pi
Ideally you will buy a version 3, but if you have a version 2 or even a Model B lying in the cupboard, give it a try. Because, believe it or not, that's all you need to send pictures across the shack! But to do this you will have to read another section of the user manual and follow some instructions for "ugly mode" contained in the initial set up guide.
- Do not connect a mouse, keyboard or monitor to the Rpi
If you do not want to always have a computer connected, you'll need to buy the touchscreen. But make sure you buy the right one from Amazon - other ones that look the same but they may not work and may even use pins on the Rpi GPIO that we already use for other connections.
The Raspberry camera
Easycap USB dongle
Readily available from eBay, these USB dongles have a yellow video phono connector and will enable you to connect your mixing desk, old camcorder or even your old VHS tape machine!
Audio input
Presumably you want people to hear what you are saying so will also need a USB audio dongle - there's loads on ebay :-) Note: there's no audio in the MPEG-4 mode at the moment but we are working on it.
Modulator Filter PCB
To get your Portsdown on air properly with DATV on 146, 437 and 23cms you'll need a modulator / filter board - this is the only piece of custom hardware and you can buy blank PCBs or built units (from the end of February 2017) from the BATC shop.
ADF4351 Local Oscillator
As well as the Modulator Filter board you will need an ADF4351 chip to use as your local oscillator. Luckily, these are available from ebay ready assembled on a small PCB with an SMA connector so it really is "plug and play".
It is possible to buy ADF4351 modules with a 10 or 25 MHz reference oscillator - you must select which reference oscillator you have in the set up menu.
These are modules are available now and the Portsdown transmitter will definitely use one, so why not buy one and you'll be ready when the Modulator board is available.
Local Oscillator filters
Testing on the 3 prototype boards has shown that, due to the square wave output of the ADF4351, it will need band switched filtering on the output of the module when used on 146 and 437 MHz - no filtering is required on 23cms. The effect of running without a high pass filter on 146 and 437 is a reduced MER and RF performance.
GPIO extender board
In order to get at all 13 signals we need to and from the Rpi, we need to use a GPIO breakout board - you can use a standard Rpi board but the card must break out all 40 pins of the GPIO, and have another connector on top for the LCD display.
Because of this the Portsdown team have designed a board specifically for Portsdown and it is available from the BATC shop. For more details see the hardware overview.
Filters and drivers
That's all there is to the Portsdown transmitter - 6 simple parts, but of course, just like any other DATV transmitter, you will need filters and driver amplifiers - there's lot of designs around and anything you have built or bought for Digilite or DTX1 will work well with the Portsdown transmitter.
Take a look in the filters section of the wiki.
Where to buy the components?
Now you really do need to read the hardware overview as at the bottom of that page is a list of suppliers with links to their website where you can buy all the components needed or you could just leap to the hardware assembly instructions.
