Initial setup
Revision as of 09:05, 15 February 2017 by G8GTZ (talk | contribs) (→Initial set up)
Initial set up
Once you have a Rpi and an SD card with the Portsdown firmware installed - either from the BATC shop or by following the instructions in this section of the user guide - the system must be initially setup.
This done using an external PC running 2 pieces of software - the first application is to find the IP address of your RPi when it first boots up, such as Advanced IP Scanner and an SSH Terminal application such as Putty - make sure you use a recent version of putty or it may reject the Rpi security certificate.
  • Connect your touchscreen and any other peripherals such Pi camera and audio dongle but do not connect a monitor or keyboard to the Raspberry Pi.
  • Using a network lead (not wifi at this stage), connect the RPi to the same network as your PC, install the SD card and turn the Rpi on (you do not need a keyboard, mouse or monitor connected to the Rpi).
  • After 30 secs to give time for the Rpi to boot up, run the IP Scanner program on your PC - scan for devices and after a few seconds it will list all the devices on your network including one from the Raspberry Pi foundation - this is your Rpi so note down the IP address listed against it. You can now close the IP scanner program.
  • Open Putty or SSH terminal program, enter the IP address of your RPi and open a connection. The first time that you do this, you will get a security warning; accept it. At the logon prompt enter the default username of "pi" and the password given to you with the card (if you have created your own card from GitHub the password will be "raspberry"). The Portsdown console menu will start automatically, and you should see a BATC Logo on the touchscreen. If there is nothing on the touchscreen, try a shutdown, power-off and re-start. You will see the following screen on the PC:
  • System Setup. It is important that you set your display type first here, so select Display. If you want to use the Waveshare touchscreen to control the Portsdown, select it with the spacebar and press enter. Then go into the Shutdown menu and reboot to apply this change.
  • System Setup Autostart. After you have selected the display type, you can select how you want your RPi to start up.
