146 MHz RB-TV
Revision as of 11:21, 16 February 2017 by G8GTZ (talk | contribs)
UK radio amateurs with full licenses have been given access to an extension of the 2mts band between 146 and 147 MHz but only for experimental modes. This is done on a temporary basis and you will need to do an on-line application for a NoV to your current license using this link:
http://rsgb.org/main/operating/licensing-novs-visitors/online-nov-application/146mhz-147mhz-nov/
The RSGB band plan now includes (and encouraged) the use of Reduced Bandwith Digital ATV (RB-TV) using 500 KHz centered on 146.5 MHz.
RB-TV is not possible using "normal" DATV equipment and requires the use of equipment developed specially for the mode.
Other equipment needed includes:
  • Filters
  • Power amplifiers
Sam Jewell G4DDK, 8W amplifier kits, pcb, manual etc. http://www.g4ddk.com/144MHz8WPA.pdf
Anglia Live, suppliers of Mitsubishi power modules http://www.anglia-live.com/products/rf-products/rf-discretes-modules/rf-mosfets/list/perpage/21/page/1
60W power amplifier pcb (available from G4DDK above) http://www.ifwtech.co.uk/g3sek/vhfdx/gm3sek-pa-module-board
  • Receive equipment
Roberto Zech Elektronik DG0VE, upconverter, power amplifier, mixer/oscillator module, LNA etc. http://www.dg0ve.de/en/index.htm
Minitioune latest software download http://www.vivadatv.org/viewtopic.php?f=81&t=367
Minitiouner building information https://wiki.batc.tv/Minitioune
BATC Shop, NIM tuner, pcb’s, other components etc. http://batc.org.uk/shop/hardware-and-kits
