The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used modes so enabling it to be used on ATV repeaters but also for RB-TV Dx working.
• Frequency coverage of 146 MHz, 437 MHz and 23cms
System overview
Touch screen control A touch screen interface (available from Amazon) on the RPi enables the system to be used without further need to connect up keyboard and mouse. If the LCD is not available, the system can be controlled by using an external PC connected over a wired or wi-fi network (console mode).
Modulator and Filter board
Audio and video inputs
Next steps?
