Revision as of 09:26, 21 February 2017 by G8GTZ (talk | contribs)
The Portsdown DATV transmitter project provides an easy way to “get on air” with Digital ATV at a relatively low cost covering all of the commonly used DATV modes so enabling it to be used for cross town QSOs and accessing ATV repeaters but also for RB-TV Dx working.
• Frequency coverage of the 146 MHz, 437 MHz and 23cms ATV bands
System overview
At the heart of the The Portsdown Transmitter|Portsdown project transmitter is a Raspberry Pi (RPi) computer running a BATC customised version of the F5OEO rpidatv software. The choice of the RPi is primarily due to the fact that it has an on-board MPEG-4 (H264) encoder and the versatile hardware interface (GPIO) capabilities.
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
