QPSKRF or Ugly mode
The F5OEO software has a QPSKRF or “ugly” test mode which directly generates a DATV signal on 437 MHz using the internal RPi clocks. This facility is available in the Portsdown transmitter as it is very useful for initial across the shack testing but has limited functionality and as its name implies, is not suitable for putting on air even if bandpass filters are used.
Image of UGLY mode spectrum
Ugly mode needs to be selected as the output mode using the console menu and has a number of functional limitations including:
- It will not work reliably above 333 Ksymbols
- Select the Desktop as the output as it may not work reliably with the internal test patterns
- Do not connect an aerial or piece of wire to the GPIO output pin (especially if you are using a plug top PSU) as there is a chance you will blow up your Rpi due to earth loops. Experience has shown it is enough just to lay a receive pick up loop close to the Rpi GPIO connector.
