MiniTioune
Revision as of 15:34, 21 February 2017 by G8GTZ (talk | contribs)
MiniTioune (also called Minituner) is a PC based system for receiving digital TV transmissions. It can be used to receive DVB-S QPSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 112Ksymbols per second enabling it to receive satellite broadcasts, "normal" ATV signals and Reduced Bandwidth (RB-TV) transmissions.
The hardware consists of 3 major components – the Tuner or NIM, the USB interface and power supply components.
The extended range Sharp tuner and pre-programmed USB interface module and a blank PCB are available from the BATC on line shop https://batc.org.uk/shop/hardware-and-kits – all other components are available from normal suppliers.
As of February 2017 the Sharp and Samsung tuners are no longer available and the project will use a tuner from Serit which cover from 140MHz right through to 2650 MHz without the need for any upconverters.
Also, due to different pinouts, they also need a simple adapter board to enable it to be plugged in to the Minituner standard hardware - Brian G4EWJ has designed a board and they are currently being made in China and they and the Serit tuner will be available in the BATC shop. Full details of this board are available here.
The system uses free to download DVB-S receive and analysis software called "Tutuione" written by F6DZP. The Software is hosted on the VivaDATV forum. You need a log-in to download, but here are the links:
The latest (11 January 2017) version of MiniTioune V0.5a: http://www.vivadatv.org/viewtopic.php?f=60&t=399
Software Installation
  • Look in the Minitiouner folder that you've just copied to C:\ for the small program Install_usrc_ax_winXP and run this to install the missing Codec. This is in W6HHC's notes but he doesn't say where to find it.
  • Run the MiniTiouner_v0.5a executable & perhaps adjust the decoder filters being used.
Receive upconverters and filters
As mentioned above, the Sharp tuner component (also called NIMs) used in MiniTioune only covers a maximum of 650 to 2600 MHz.
Whilst this is fine for the 23cms (1.3 GHz) and 13cms (2.3 GHz) amateur bands it does not provide coverage of 146 (2mts) and 437 MHz (70cms) where the majority of ATV operation takes place. Therefore we need to use an upconverter in front of the tuner which converts 146 MHz and 437 MHz up to an L band frequency that the MiniTioune will receive.
The new Serit tuner covers 140 - 2650 MHz and does not require any external frequency converters.
