Filters
Revision as of 09:12, 25 February 2017 by G8GTZ (talk | contribs)
It is absolutely essential that filters are used on the output of the Portsdown and any other wide band DATV transmitter such as DTX1 and DATVexpress to remove harmonics of the wanted signal. Just try tuning your receiver to 439.5 when transmitting on 146.5 MHz!
The same also applies to the input of any ATV or DATV receiver which uses a wide band satellite tuner in the front end (and they all do!) - this is because these tuners were designed to be used in a "closed system" and connected directly to an LNB on a dish pointing at the clear sky. This is very different to being connected to a "wide band" yagi antennae which will also pick up PMR and paging systems, short range devices and broadcast transmitters many of which are digital and just produce white noise so you cannot tell you are being overloaded by them!
Reasonable filters are actually quite easy to build - a great place to start if you fancy that is W1GHZ paper on making filters from an Altoid's tin (any other metal tin will do) - http://www.w1ghz.org/filter/Altoids_Tin_Filters.pdf
If you want to design one from scratch Doug, both VK3UM, now sadly missed, has a calculator http://www.vk3um.com/interdigital%20filter.html or there's a lot of filter designs available for DIY build or to buy listed on these pages:
