Revision as of 08:45, 27 February 2017 by G8GTZ (talk | contribs)
• Frequency coverage of the 146 MHz, 437 MHz and 23cms ATV bands
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
