Serit tuner
Revision as of 11:04, 1 March 2017 by G8GTZ (talk | contribs)
As of February 2017 the Sharp and Samsung tuners are no longer available and the Minituner project will use a tuner from Serit which cover from 140MHz right through to 2650 MHz without the need for any upconverters.
Also, due to a different pinouts from the Sharp NIM, the Serit tuner will also need a simple adapter board to enable it to be plugged in to the Minituner standard hardware - Brian G4EWJ has designed a board and they are currently being made in China. The board and a full set of components plus the Serit tuner will be available in the BATC shop.
Details of the Serit tuner and adaptor board will be posted here.
