Serit tuner
Revision as of 11:45, 1 March 2017 by G8GTZ (talk | contribs)
As of February 2017 the Sharp and Samsung tuners are no longer available and the Minituner project will use a tuner from Serit which cover from 140MHz right through to 2650 MHz without the need for any upconverters.
Filters and pre-amps
Adapter card
Also, due to a different pinouts from the Sharp NIM, the Serit tuner will also need a simple adapter board to enable it to be plugged in to the Minituner standard hardware - Brian G4EWJ has designed a PCB and the board with a full set of components plus the Serit tuner is available in the BATC shop.
File:MiniTiouner MTK2 Instructions v1-03.pdf
