Serit tuner
As of February 2017 the Sharp and Samsung tuners are no longer available and the Minituner project will use a tuner from Serit which cover from 140MHz right through to 2650 MHz without the need for any upconverters.
Dual receiver
The Serit tuner is capable of receiving more than one signal simultaneously; however the BATC hardware and software can only receive one signal at a time. There is provision for a socket on the converter PCB to connect to the second receive output of the FTS4335V for experimentation, but software is currently not available to use it.
Filters and pre-amps
To use the Serit tuner you will need to run Ver 0.6d or later versions of the excellent Minitioune software. This is available for download from here and will work with Sharp, Eardatek or Serit tuners.
Adapter card
Also, due to a different pinouts from the Sharp NIM, the Serit tuner will also need a simple adapter board to enable it to be plugged in to the Minituner standard hardware.
Brian G4EWJ has designed a PCB and the blank board plus a full set of (leaded) components and the Serit tuner is available in the BATC shop.
File:MiniTiouner MTK2 Instructions v1-03.pdf
