MiniTioune
Revision as of 07:10, 2 March 2017 by F6DZP (talk | contribs)
MiniTioune (software)+ MiniTiouner (hardware) is a PC based system for receiving digital TV transmissions. It can be used to receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second enabling it to receive satellite broadcasts, "normal" ATV signals and Reduced Bandwidth (RB-TV) transmissions.
The simple hardware is designed for home construction and consists of 3 major components – the Tuner or NIM, the USB interface and power supply components.
Full details on how the build the MiniTiouner including a "how to video" and a zip file containing circuit diagram, layout and build instructions can be found on the Minituner hardware wiki page. Please note the “full kit” mentioned in documentation is no longer available.
Serit tuner
As of February 2017 the Sharp and Samsung tuners are no longer available and the project will use a NIM tuner from Serit FTS4335 which cover from 143.75 MHz right through to 2450 MHz without the need for any upconverters.
Band Pass filters
Receive upconverters
The latest (11 January 2017) version of MiniTioune V0.6d: Minitioune v0.6d download
Software Installation
 There is a "readme.pdf" in the Minitioune software package
