MiniTioune
MiniTioune (software)+ MiniTiouner (hardware) is a PC based system developed by Jean-Pierre F6DZP for receiving digital TV transmissions. It can be used to receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second enabling it to receive satellite broadcasts, "normal" ATV signals and Reduced Bandwidth (RB-TV) transmissions.
The simple hardware is designed for home construction and consists of 3 major components – the Tuner or NIM, the USB interface and power supply components.
When used with the Sharp or Samsung tuner or NIM component, frequency coverage is from 650 MHz through to 2600 MHz. (DVB-S and DVB-S2 QPSK and 8PSK)
When used with the Serit FTS4335 NIM component, frequency coverage is from 143.75 MHz through to 2450 MHz. (DVB-S and DVB-S2 QPSK, 8PSK, 16APSK and 32APSK)
This extended frequency coverage gives greater flexibility when working with up converters from the VHF bands and enables the 10 GHz band, including Es'HailSat-2 down link, to be received on a standard domestic PLL LNB.
Serit tuner
As of February 2017 the Sharp and Samsung tuners are no longer available and the project will use a NIM tuner from Serit FTS4335 which cover from 143.75 MHz right through to 2450 MHz without the need for any upconverters.
Band Pass filters
Receive upconverters
The latest (11 January 2017) version of MiniTioune V0.6d: Minitioune v0.6d download
Software Installation
 There is a "readme.pdf" in the Minitioune software package
