Serit tuner
As of February 2017 the Sharp and Samsung tuners are no longer available and the MiniTiouner project will use a tuner NIM from Serit (FTS-4335) which covers from 143.75MHz right through to 2450 MHz without the need for any upconverters. The first prototype was exposed at CAT16 ( images/d/df/MiniTiouner_CAT16.pdf ) by Jean-Pierre F6DZP
Feedback
Dual receiver
Filters and pre-amps
To use the FTS4335 MiniTiouner you will need to run Ver 0.6d or later versions of the excellent MiniTioune software. This is available for download from the Viva DATV forum here and will work with Sharp, Eardatek or Serit tuners. You need to register on the Viva DATV forum before being able to download.
Adapter card
Also, due to a different pinouts from the Sharp NIM, the FTS4335 MiniTiouner will also need a simple adapter board to enable it to be plugged in to the MiniTiouner standard hardware.
Brian G4EWJ has designed a PCB and the blank board plus a full set of (leaded) components and the Serit MiniTiouner is available in the BATC shop.
Instructions and Parts List
media:Serit_FTS4335V_Converter_Kit_MTK2_Instructions_v1-04_Parts_Build_A1_v1.zip
