Revision as of 08:51, 4 March 2017 by G8GTZ (talk | contribs)
The aim of the project is to enable an amateur radio operator with little or no knowledge of Digital ATV to construct the hardware elements, load and configure the software and use the system to send live Digital ATV signals across town on his existing aerials.
• Frequency coverage of the 146 MHz, 437 MHz and 23cms ATV bands
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
