MiniTioune
MiniTioune (software)+ MiniTiouner (hardware) is a PC based system developed by Jean-Pierre F6DZP for receiving digital TV transmissions. It can be used to receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second enabling it to receive satellite broadcasts, "normal" DATV signals and Reduced Bandwidth (RB-TV) transmissions.
Definitions
  • MiniTioune = PC software
  • Serit FTS4335 NIM = Current version of NIM sold by the BATC shop. Note the project also worked with an earlier Serit tuner (SP2246) but none were sold by the BATC
  • NIM = Network Interface Module. A little metal box that we can find inside most of Satellite Receivers. We can find 2 chips : the Zero Tuner and the Demodulator. RF Signal is sent to the antenna connector "RF input", it is amplified by a transistor "booster", the zero tuner selects the frequency asked and the demodulator extracts the data (Transport Stream) that goes outside the NIM on a digital parallel output.
inside a NIM
The Minitiouner hardware is designed for home construction and consists of 3 major components – the Tuner or NIM, the USB interface and power supply components.
When used with the Sharp, Samsung or Serit SP2246 NIM component, frequency coverage is from 650 MHz through to 2600 MHz. (DVB-S and DVB-S2 QPSK and 8PSK)
When used with the Serit FTS4335 NIM component, frequency coverage is from 143.75 MHz through to 2450 MHz. (DVB-S and DVB-S2 QPSK, 8PSK, 16APSK and 32APSK)
This extended frequency coverage gives greater flexibility when working with up converters from the VHF bands and enables the 10 GHz band, including Es'HailSat-2 down link, to be received on a standard domestic PLL LNB.
Serit FTS4335 NIM tuner
As of February 2017 the Sharp, Samsung and Serit SP2246 tuners are no longer available and the project will use a NIM tuner from Serit FTS4335 which cover from 143.75 MHz right through to 2450 MHz without the need for any upconverters.
Band Pass filters
Receive upconverters
Software Installation
