Revision as of 11:37, 7 March 2017 by G8GTZ (talk | contribs) (Created page with "The latest Software for the Portsdown Transmitter is version 201703060 (the version is the issue date with an added 0-9 serial) and can be found here: https://github.com/Briti...")
The latest Software for the Portsdown Transmitter is version 201703060 (the version is the issue date with an added 0-9 serial) and can be found here: https://github.com/BritishAmateurTelevisionClub/rpidatv. This software supports the following:
Supported hardware
The Pi will control an ADF4351 Synthesizer with a 10 or 25 MHz Reference Oscillator, and can accept video input from an EasyCap type USB capture device and from a Pi Camera.
Currently the Pi will output a dirty (ugly) QPSK signal on 437 MHz for testing, send I and Q signals to the Portsdown Filter/modulator board, and control a DATV Express in DVB-S mode.
For use as a basic DVB-S H264 LeanDVB signal monitor, an RTL-SDR is required.
Modes
  • In streaming mode, it will send RPi Camera pictures and USB dongle sound to the BATC Streamer, or to any other compatible streamer.
  • With an added RTL-SDR, the included LeanDVB monitor receiver will display strong DVB-S H264 signals of up to 500 KS/s.
Issues
If an EasyCap device is plugged in, some Pi Camera modes do not work.
Future Enhancements
  • Streaming (with sound) from an external video input (EasyCap)
  • Implement fix for DigiThin mode and test it.
  • Provide a shutdown option from the touchscreen
  • Adjust the Test Card sizes
  • Add sound channel to H264 video modes
Version history
Last updated 7 Mar 17. DGC
