The latest Software for the Portsdown Transmitter is version 201703060 (the version is the issue date with an added 0-9 serial).
Supported hardware
  • The Pi will control an ADF4351 Synthesizer with a 10 or 25 MHz Reference Oscillator.
  • Video input from an EasyCap type USB capture device and from a Pi Camera.
Outputs
Currently the Portsdown s/w will output to:
  • Control a DATV Express in DVB-S mode.
  • Stream to RTMP server such as batc.tv (see restrictions below)
It also supports a basic DVB-S H264 LeanDVB signal monitor (an RTL-SDR is required).
Modes
  • In streaming mode, it will send RPi Camera pictures and USB dongle sound to the BATC Streamer, or to any other compatible streamer.
  • With an added RTL-SDR, the included LeanDVB monitor receiver will display strong DVB-S H264 signals of up to 500 KS/s.
Issues
If an EasyCap device is plugged in, some Pi Camera modes do not work.
Future Enhancements
  • Streaming (with sound) from an external video input (EasyCap)
  • Implement fix for DigiThin mode and test it.
  • Provide a shutdown option from the touchscreen
  • Adjust the Test Card sizes
  • Add sound channel to H264 video modes
Version history
Last updated 7 Mar 17. DGC
