Minitiouner Hardware
Revision as of 09:35, 24 March 2017 by G8GTZ (talk | contribs)
The MiniTiouner, developed and designed by Jean-Pierre F6DZP, is a DVB-S/S2 USB receiver card and measurement tool that works with the software "Minitioune".
BATC PCB
Brian G4EWJ has designed a PCB for the BATC to enable easy home construction of the MiniTiouner hardware - components for over 200 units have been sold around the world.
All the project documentation is available for download in the zip file:
File:MTK1 Instructions v1-9, Parts v5, Overlay, Schematic v1.zip
Colin G4KLB has done an excellent video on constructing the MiniTiouner:
https://www.youtube.com/watch?v=vXUIQPeslwM
When you have built your MiniTiouner, you can check it using the software "TestMyMiniTiouner" included in the Minitioune software package.
Compatible NIM types
  • Samsung DNBU10711IST
  • Samsung DNBU10512IST
  • LG TDQX-S001F
  • Serit SP2246
  • Serit FTS-4335 (Sold by BATC shop in 2017)
Fitting a lock detector
