MiniTioune
The MiniTioune USB receiver project consists of software (MiniTioune )and hardware (MiniTiouner) and is developed by Jean-Pierre F6DZP for receiving digital TV transmissions.
It can be used to receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second enabling it to receive satellite broadcasts, "normal" DATV signals and Reduced Bandwidth (RB-TV) transmissions.
Definitions
  • MiniTioune = PC software
  • NIM = Network Interface Module. The little metal box that we find inside most of Satellite Receivers and used to be called the tuner - contains the RF and demodulation circuits.
Hardware description
  • The NIM
A NIM typical consists of 2 chips : the Zero Tuner and the Demodulator. RF Signal is sent to the antenna connector "RF input", it is amplified by a transistor "booster", the zero tuner selects the frequency asked and the demodulator extracts the data (Transport Stream) that goes outside the NIM on a digital parallel output.
inside a NIM
  • Serit FTS4335 NIM = Current version of NIM sold by the BATC shop. Note the project also worked with an earlier Serit tuner (SP2246) but none were sold by the BATC
So what do I need to buy?
The Minitiouner hardware is designed for home construction and consists of 3 major components – the Tuner or NIM, the USB interface and PCB containing the power supply components.
  • The USB interface can be bought ready programmed from the BATC shop.
  • The main PCB can also be bought from the BATC shop although we are currently (April 2017) redesigning the board for one that will take the Serit tuner directly.
  • The tuner or NIM. The BATC shop used to sell the Sharp and Eardetek component with frequency coverage from 650 MHz through to 2600 MHz. (DVB-S and DVB-S2 QPSK and 8PSK).
We now sell the Serit FTS4335 NIM component with frequency coverage is from 143.75 MHz through to 2450 MHz. (DVB-S and DVB-S2 QPSK, 8PSK, 16APSK and 32APSK) This extended frequency coverage gives greater flexibility when working with up converters from the VHF bands and enables the 10 GHz band, including Es'HailSat-2 down link, to be received on a standard domestic PLL LNB.
Serit FTS4335 NIM tuner
As of February 2017 the Sharp, Samsung and Serit SP2246 tuners are no longer available and the project will use a NIM tuner from Serit FTS4335 which cover from 143.75 MHz right through to 2450 MHz without the need for any upconverters.
Band Pass filters
Receive upconverters
Software Installation
