MiniTioune software
Jump to navigation
Jump to search
The MiniTiouner USB receiver uses free to download DVB-S receive and analysis software called "Minitioune" written by F6DZP. The Software is hosted on the VivaDATV forum. You need a log-in to download, but here are the links:
Software Installation
- Install the D2XX drivers 2.12.24 found at http://ftdichip.com/Drivers/D2XX.htm. There's a link in the right column for a setup executable. This stage is missing from W6HHC notes.
- Run the MiniTiouner_v0.6d executable & perhaps adjust the decoder filters being used.
