MiniTioune
Revision as of 08:57, 5 April 2017 by G8GTZ (talk | contribs)
The MiniTioune USB receiver project consists of software (MiniTioune) and hardware (MiniTiouner) and is developed by Jean-Pierre F6DZP for receiving digital TV transmissions.
It can be used to receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second. It can be used to receive satellite broadcasts, "normal" DATV signals and is the ONLY system capable of receiving Reduced Bandwidth (RB-TV) transmissions.
Definitions
  • MiniTioune = PC software
Hardware overview
Full details of the MiniTiouner hardware and build information are available here
The NIM
The NIM or Network interface module is the little metal box that we find inside most of Satellite Receivers (also called the tuner) and typically contains 2 chips : the Zero Tuner and the Demodulator. RF Signal is sent to the antenna connector "RF input", it is amplified by a transistor "booster", the zero tuner selects the frequency asked and the demodulator extracts the data (Transport Stream) that goes outside the NIM on a digital parallel output.
inside a NIM
The BATC shop used to sell a Sharp and Eardetek NIM with frequency coverage from 650 MHz through to 2600 MHz. (DVB-S and DVB-S2 QPSK and 8PSK). As of February 2017 the Sharp, Samsung and Serit SP2246 tuners are no longer available and the project now uses a NIM tuner from Serit (model FTS4335) which covers from 143.75 MHz right through to 2450 MHz without the need for any upconverters.
However, due to a different pinouts from the Sharp NIM, the Serit FTS4335 NIM tuner will also need a simple adapter board to enable it to be plugged in to the MiniTiouner standard hardware - Brian G4EWJ has designed a board and these are available from the BATC shop. The adapter board, designed by Brian G4EWJ, and the Serit FTS4335 NIM tuner are available from the BATC shop.
Note:  As of April 2017 a new main PCB is being designed to directly take the Serit tuner - any new constructors should wait for the new board which will not need the adapter PCB. You only require the adaptor PCB if you are upgrading existing MiniTiouner hardware to include the Serit tuner.
Note the project also worked with an earlier Serit tuner (SP2246) but none were sold by the BATC
USB module
PCB and Power supply
The rest of the MiniTiouner components provide the 1v, 3.3v and 5v supplies - these are mounted on the blank PCB supplied by the BATC shop.
So what do I need to buy?
  • The main PCB can be bought from the BATC shop. Note we are currently (April 2017) redesigning the board for one that will take the Serit tuner directly.
  • Serit adapator PCB? See note above
  • SUP2400 70cms upconverter - The BATC shop sells this unit which is used to upconvert 146 and 70cms to L band. You do not need to buy it if you are using the Serit tuner.
Band Pass filters
Receive upconverters
Full details of the MiniTioune software designed to be used with the MiniTiouner hardware are available here MiniTioune software.
