Serit tuner
  • If neither of those apply, you don't need one! It does not perform any better than a Sharp - in fact it needs more gain in front of it.
Adapter card
Due to a different pinouts from the Sharp NIM, the Serit FTS4335 NIM will also need a simple adapter board to enable it to be plugged in to the original MiniTiouner PCB available from the BATC shop.
Brian G4EWJ has designed a PCB and the blank board and the Serit FTS-4335V NIM is available in the BATC shop.
Note:  As of April 2017 a new main PCB is being designed to directly take the Serit tuner - any new constructors should wait for the new board which will not need the adapter PCB. You only require the adaptor PCB if you are upgrading existing MiniTiouner hardware to include the Serit tuner.
Filters and pre-amps
The wide band coverage makes building a receiver for 146 or 437 much easier, although you will need a pre-amp followed by lots of filtering for each band, just like the Sharp did, and probably followed by a Satellite line amp from ebay as the Serit FTS-4335 has less gain than the Sharp.
Dual receiver
NIM pinouts
