The aim of the project is to enable an amateur radio operator with little or no knowledge of Digital ATV to construct the hardware elements, load and configure the software and use the system to send live Digital ATV signals across town on his existing aerials.
• Frequency coverage of the 146 MHz, 437 MHz and 23cms ATV bands
Note - the Portsdown project has evolved since the original articles were written and now defines just the Raspberry Pi based transmitter - there is no Portsdown receiver project although it is possible to add an RTL dongle based monitoring receiver. The MiniTioune USB receiver project is the recommended receive solution for all DATV transmissions including the Portsdown.
System overview
Touch screen control
Modulator and Filter board
Audio and video inputs
Next steps?
