PTT and band switching
Band outputs
| Frequency Mhz | ATV Band | Pin 28 | Pin 35 |
| < 100 MHz | 71 MHz | Lo | Lo |
| 100 - 250 MHz | 146 MHz | Lo | Hi |
| 250 - 950 MHz | 437 MHz | Hi | Lo |
| 950 - 4400 MHz | 23cms | Hi | Hi |
GPIO band decoder
Tx Rx sequencer
We also recommend the use of a Tx / Rx sequencer to ensure your mast head relay has changed over and your expensive pre-amp is de-powered before you start transmitting. Many circuits and pre-built designs are available including this simple single chip design by Ian Waters G3KKD published in CQ-TV 125.
Also rather than use these pins to switch an expensive RF relay on the output of Portsdown, take a look at this simple idea to use a duplexer / triplexer.
Summary of GPIO connections
The BCM numbers in this table correspond to the connector labelling on the Willow Electronics GPIO breakout board. Two of the connections are not broken out and need to be directly connected to the GPIO pins. More details to follow.
