MiniTioune
Revision as of 19:47, 9 April 2017 by G8GTZ (talk | contribs)
The MiniTioune receiver project, developed by Jean-Pierre F6DZP, consists of the home constructed MiniTiouner hardware which interfaces via a standard USB 2.0 port to a Windows PC running the MiniTioune software.
It will receive DVB-S QPSK and DVB-S2 QPSK, 8PSK, 16APSK, 32 APSK from broadcast and amateur TV transmissions with symbol rates (SR) from 30 Msymbols down to 120 Ksymbols per second.
It can be used to receive satellite broadcasts, "normal" DATV signals and is the ONLY system capable of receiving Reduced Bandwidth (RB-TV) transmissions.
Definitions
  • MiniTioune = PC software
Hardware overview
Full details of the MiniTiouner hardware and build information are available here and consists of 3 major elements:
The NIM
inside a NIM
Note the project also worked with an earlier Serit tuner (SP2246) but none were sold by the BATC
USB module
PCB and Power supply
The rest of the MiniTiouner components provide the 1v, 3.3v and 5v supplies - these are mounted on the blank PCB supplied by the BATC shop.
So what do I need to buy?
  • The main PCB can be bought from the BATC shop. Note we are currently (April 2017) redesigning the board for one that will take the Serit tuner directly.
  • Serit adapator PCB? See note above
  • SUP2400 70cms upconverter - The BATC shop sells this unit which is used to upconvert 146 and 70cms to L band. You do not need to buy it if you are using the Serit tuner.
Band Pass filters
Receive upconverters
Full details of the MiniTioune software designed to be used with the MiniTiouner hardware are available here MiniTioune software.
