Minitiouner Hardware
The MiniTiouner, developed and designed by Jean-Pierre F6DZP, is a DVB-S/S2 USB receiver card and measurement tool that works with the software "Minitioune".
Overview
The MiniTiouner hardware consists of 3 main parts:
PCB and Power supply
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails.
There are 2 variants of the MiniTiouner main PCB.
Version 2
As from April 2017 only the version 2 PCB designed by Mike G0MJW is available - only the wide coverage Serit Tuner can be used with this board.
See this page for more details, part list and construction tips.
Version 1
Version 1 was the original PCB designed by Brian G4EWJ and sold in the BATC shop.
to enable easy home construction of the MiniTiouner hardware - components for over 200 units have been sold around the world.
All the project documentation is available for download in the zip file:
File:MTK1 Instructions v1-9, Parts v5, Overlay, Schematic v1.zip
Colin G4KLB has done an excellent video on constructing the MiniTiouner:  https://www.youtube.com/watch?v=vXUIQPeslwM
When you have built your MiniTiouner, you can check it using the software "TestMyMiniTiouner" included in the Minitioune software package. The rest of the MiniTiouner components provide the 1v, 3.3v and 5v supplies - these are mounted on the blank PCB supplied by the BATC shop.
USB module
The NIM
inside a NIM
Compatible NIM types
  • Samsung DNBU10711IST
  • Samsung DNBU10512IST
  • LG TDQX-S001F
  • Serit SP2246
  • Serit FTS-4335 (Sold by BATC shop in 2017)
So what do I need to buy?
  • The main PCB can be bought from the BATC shop. Note we are currently (April 2017) redesigning the board for one that will take the Serit tuner directly.
  • Serit adapator PCB? See note above
  • SUP2400 70cms upconverter - The BATC shop sells this unit which is used to upconvert 146 and 70cms to L band. You do not need to buy it if you are using the Serit tuner.
Fitting a lock detector
