Minitiouner Hardware
The MiniTiouner, developed and designed by Jean-Pierre F6DZP, is a DVB-S/S2 USB receiver card and measurement tool that works with the software "Minitioune".
Original schematics are here : http://www.vivadatv.org/viewtopic.php?f=80&t=366
Overview
The MiniTiouner hardware consists of 2 main parts which sit on a main PCB which is sold by the BATC shop.
MiniTiouner main board PCB
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails and there are 2 variants of the MiniTiouner main PCB - as of April 2017 new builders should only refer to the version 2 build documentation.
See this page for more details, part list and construction tips.
Version 1
Version 1 was the original PCB designed by Brian G4EWJ and sold in the BATC shop until early 2017 - this board is no longer available and new builders should read the version 2 build documentation.
USB module
The NIM
The NIM or Network interface module is the little metal box found inside Satellite Receivers (also called the tuner) and typically contains 2 chips : the Zero Tuner and the Demodulator. RF Signal is sent to the antenna connector "RF input", it is amplified by a transistor "booster", the zero tuner selects the frequency asked and the demodulator extracts the data (Transport Stream) that goes outside the NIM on a digital parallel output.
Note: As of April 2017 a new main PCB is being designed to directly take the Serit tuner - any new constructors should wait for the new board which will not need the adapter PCB. You only require the adaptor PCB if you are upgrading existing MiniTiouner hardware to include the Serit tuner. Check this page to work out if you should upgrade.
Compatible NIM types
- Zero tuner chip can be STB6100, STV6110, STV6111, STV6120
- Demodulator chip STV0903, STV0913, STV0910
- Eardatek EDS-4B47FF1B+ (sold by BATC shop during 2015 / 16)
- Sharp F7VZ0169 (sold by BATC shop during 2016)
- Samsung DNBU10711IST
- Samsung DNBU10512IST
- LG TDQX-S001F
- Serit SP2246
- Serit FTS-4335 (Sold by BATC shop in 2017)
So what do I need to buy?
- The USB interface is available ready programmed from the BATC shop.
- The main PCB can be bought from the BATC shop. Note we are currently (April 2017) redesigning the board for one that will take the Serit tuner directly.
- Serit adapator PCB? See note above
- The tuner or NIM. The Serit unit covering 143 - 2450 MHz is available from the BATC shop
- SUP2400 70cms upconverter - The BATC shop sells this unit which is used to upconvert 146 and 70cms to L band. You do not need to buy it if you are using the Serit tuner.
Fitting a lock detector
