Minitiouner Hardware
Revision as of 19:29, 30 April 2017 by G8GTZ (talk | contribs) (→Version 1)
The MiniTiouner, developed and designed by Jean-Pierre F6DZP, is a DVB-S/S2 USB receiver card and measurement tool that works with the software "Minitioune".
Overview
The MiniTiouner hardware consists of 2 main parts which sit on a main PCB which is sold by the BATC shop.
MiniTiouner main board PCB
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails and there are 2 variants of the MiniTiouner main PCB - as of April 2017 new builders should only refer to the version 2 build documentation.
See this page for more details, part list and construction tips.
Version 1 - before Jan 2017
USB module
The NIM
inside a NIM
Compatible NIM types
  • Samsung DNBU10711IST
  • Samsung DNBU10512IST
  • LG TDQX-S001F
  • Serit SP2246
  • Serit FTS-4335 (Sold by BATC shop in 2017)
So what do I need to buy?
  • The main PCB can be bought from the BATC shop. Note we are currently (April 2017) redesigning the board for one that will take the Serit tuner directly.
  • Serit adapator PCB? See note above
  • SUP2400 70cms upconverter - The BATC shop sells this unit which is used to upconvert 146 and 70cms to L band. You do not need to buy it if you are using the Serit tuner.
Fitting a lock detector
