Serit tuner
  • If neither of those apply, you don't need one! It does not perform any better than a Sharp - in fact it needs more gain in front of it.
Serit tuner main board
Mike G0MJW has designed a PCB specifically for use with the Serit tuner.
Filters and pre-amps
The wide band coverage makes building a receiver for 146 or 437 much easier, although you will need a pre-amp followed by lots of filtering for each band, just like the Sharp did, and probably followed by a Satellite line amp from ebay as the Serit FTS-4335 has less gain than the Sharp.
Dual receiver
NIM pinouts
Serit datasheets
File:FTS-4335 Series_F2.pdf
File:FTS-4334L Series_F1.pdf
