Minitiouner Hardware
The MiniTiouner, developed and designed by Jean-Pierre F6DZP, is a DVB-S/S2 USB receiver card and measurement tool that works with the software "Minitioune".
What do I need to buy?
The Minitiouner hardware is designed for home construction and consists of the 3 main components described on these wiki pages - to build the unit you only need to buy the following and then download the free MiniTioune software.
  • The main version 2 PCB can be bought from the BATC shop.
New builders will use the Serit tuner and version 2 PCB and only need to read this wiki page.
Overview
The MiniTiouner hardware consists of 2 main parts which sit on a main PCB which is sold by the BATC shop.
MiniTiouner main PCB
The main PCB contains the power supply for the 5, 3.3 and 1 volt rails and there are 2 variants of the MiniTiouner main PCB - as of April 2017 new builders should only refer to the version 2 build documentation.
See this page for more details, part list and construction tips.
Version 1 - before Jan 2017
USB module
The NIM
inside a NIM
Compatible NIM types
  • Samsung DNBU10711IST
  • Samsung DNBU10512IST
  • LG TDQX-S001F
  • Serit SP2246
  • Serit FTS-4335 (Sold by BATC shop in 2017)
Fitting a lock detector
